Old 8th February 2011, 10:43 PM
TSM Locost's Avatar
The parts i got from a 2.0ltr Automatic were as follows,
Rear disc's with bolt in drive shafts and 3.62 diff. Ok.
Front disc's 260mm instead of std 240mm.with larger calipers. Ok
Brake master cylinder no use as abs all round = binned
No idea of year or which 2.0lt engine.
HTH.
Be Lucky, Mike.
Old 9th February 2011, 11:14 AM
The gearbox is pretty much the only difference between an automatic and a normal car. The diff and shafts are going to be the same.
Old 9th February 2011, 06:52 PM
Thanks for the replys guys, will give it a lot of thought
