Old 11th February 2011, 04:09 PM
eSteve's Avatar
eSteve eSteve is offline
Default Nice work but....
Jimbob.
Great idea, very useful, but forget the car rotisserie, I want one of your double decker bicycles!
http://www.youtube.com/watch?v=G3J7-..._order&list=UL
Regards,
eSteve
Old 11th February 2011, 04:51 PM
Grand idea Jimbob and a cool video......
Keep it up.....Andrew
Old 11th February 2011, 06:30 PM
Deanno's Avatar
Deanno Deanno is offline
"The Rotating Chassis Master" I love it
if possible could you give me some dimensions.
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 12th February 2011, 06:27 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
very good you seem to have added quite alot of extra bracing to your chassis is there a particular reason for this?
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 13th February 2011, 10:44 AM
fabbyglass
I have seen chassis jigs made in a similar way, would make it a lot easier to weld up as non of that clambering malarky only to lean on a joint you just welded.....how many times and how many pairs of ovvies I went thru I dunno
Old 13th February 2011, 11:17 AM
I used to weld up 5mtr long stillages on a rotating jig, which after 45 mins of welding 6mm angle and 50x50x4 box would clamp it self around the jig. They used to make one hell of a bang as it hit the floor from 3ft up.
I would say if your planning on using one to finish weld a chassis I would make a removable flat base to clamp it to. Theres alot of unsupported weight in the middle of the chassis and don't forget that welds pull too no matter how careful you are.
Old 13th February 2011, 08:52 PM
fabbyglass
I wouldn't clamp the chassis to weld it, it will move...
