Old 22nd February 2011, 02:24 PM
Deanno's Avatar
Deanno Deanno is offline
Default Rear upright question
On the rear upright what angle do i need to rotate the threaded plate for disc brakes?
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 22nd February 2011, 02:50 PM
fabbyglass
Hang them off the back of the upright
Old 22nd February 2011, 03:37 PM
Deanno's Avatar
in the book it says dics brakes upright and for drums turn them length ways.
for discs i have seen them at an angle?
Old 22nd February 2011, 04:16 PM
think this was somthing to do with cable routing. spikehaus would be the one to ask. i think or brackets where available from 3ge to convert drum type
Old 22nd February 2011, 04:22 PM
fabbyglass
That and they clout the upright....
Old 22nd February 2011, 04:51 PM
JHewitt's Avatar
JHewitt JHewitt is offline
Have a look at enoch's fine work here http://www.deepfolly.co.uk/2.html
he turned the plate round. I don't believe there is an exact angle to turn it, just turn it round as per his pics to give a little more clearance.
Joe.
Old 22nd February 2011, 06:06 PM
Deanno's Avatar
Thanks for the help.
Old 22nd February 2011, 10:23 PM
Caliper is directly in line with top mount for shocker if made as per book for disc setup. 30 deg ish offset from vertical is some where near but may be better to trial fit before welding
Old 23rd February 2011, 08:58 AM
axle's Avatar
axle axle is offline
yes look under Handy tips and the pic on part two on enoch's diary it will save you a lot of time and headache later
Regards Axle
Old 23rd February 2011, 10:01 AM
Luke2842's Avatar
Luke2842 Luke2842 is offline
Having one of the threaded holes at 12 o'clock works, I used the top right hole.
