Old 28th February 2011, 12:05 PM
old_bill old_bill is offline
Default polo mk2 radiator
Hi all
I have bought a 2nd hand mk2 polo radiator. I am not sure of the best way to mount it. I saw a pic posted by Gus and it looks like I have to fabricate mounting brackets for the top. It's not clear how the bottom of the radiator is secured. Also Ronnie said he had mounted his polo radiator, it would be good if some pics could be posted of this. I also bought a 2nd hand nosecone from e-bay it looks as if its the one from GTS. Also while I'm here what fan would be suitable?
Thanks in advance for any help
Bill
http://www.flickr.com/photos/old_bill/
Old 28th February 2011, 12:43 PM
Bill,
Attached is a picture of how mine & Gus's radiators are mounted.
The top bracket picks up with a lug on the radiator that is tapped M6.
The bottom mounting is a simple plate with a hole drilled in it and a grommet pushed in. The leg of the radiator then pushes into the grommet.
Hope that helps.
Old 28th February 2011, 06:45 PM
Thumbs up
Thanks Dave much obliged
Bill
Old 28th February 2011, 07:22 PM
Thumbs down
Just had another look at my radiator, it doesn't have the mounting leg at the bottom. I suppose I could make something up and bond it on.
S**t if I didn't have bad luck I wouldn't have any luck at all
Bill
Old 1st March 2011, 07:41 AM
Hi Bill
I don't have a decent photo to hand but my polo rad is mounted more or less the same as Gus's
If it is one of the lower lugs that is missing you could make up some sort of L bracket & weld it to the lower front frame.
Then try & pick up on one of the lower screw mounts on the front of the rad
Old 1st March 2011, 08:45 AM
Originally Posted by Bonzo View Post
Hi Bill
Cheers Ronnie
I'll bodge something to fit
Bill
