Old 28th February 2011, 12:16 PM
Default Edge Trim
Right, I'm getting to the point where I'm covering all the sharp and exposed edges to comply with the IVA test. Some areas I'm not to sure about are the sides of the cockpit, and where it arches back, following the lines of the wheel arch. This is where my 1.2mm aluminium side panel is fitted onto. What have people done in this area to make it pass the minimum radius requirement? All the top trim I've seen is too narrow.
