Old 7th March 2011, 03:29 PM
pull it in with a plain nut then switch it for the nylock simples
Old 7th March 2011, 07:16 PM
In theory yes
The idea sort of goes down the drain after you have spent hours looking for a UNF plain nut .... Then you find one, just to find out that the ball joint maufacturer has used a Metric fine thread
Some manufactures have stuck with imperial threads & others have switched to metric fine.
Strange but True
Old 8th March 2011, 06:00 AM
Originally Posted by Bonzo View Post
In theory yes
there is just no helping some people
Old 8th March 2011, 10:17 AM
Honestly, I meant nothing by my comments Baz
Just thinking from a home workshop point of view, how many folk have access to a selection of metric & imperial fine threaded, plain nuts ?
I have a huge range of old imperial stuff & a fair bit of metric stock too .... So much so that I weighed in, 6 full builders buckets of used fixings during my last trip to the scrappy .... Got hacked off with tipping them out onto the floor looking for a particular fixing, just to find, that's the only one you dont have
Yes of course you are right mate, the simplest way to pull a ball joint up, is with a plain nut
I guess placing a few flat washers under the nyloc comes a close second.
