Old 12th November 2010, 03:43 PM
mark mark is offline
Its true that there is not a huge ammount of articulation before the joint is at the limit of its movement but in reality unless you have the suspension set very soft it doesnt reach its limit.
On the road I have my dampers (gaz)set to about 17 of 30 clicks and im confident it wouldnt run out of movement, any less and it doesnt handle as well anyway (in my opinion) on track i stiffen them up a little more.
Old 17th November 2010, 06:40 PM
Originally Posted by davedew View Post
Baz,
What you have noticed with draglink movement is how it is on all of the roadsters. I think it is one of the things Ash thinks caused his ali adjuster to fail, by pulling on the draglink once it had ran out of movement.
Any nut & bolt supplier should be able to get the M18 half nuts for you. If not you can get them on ebay.
http://cgi.ebay.co.uk/M18-x1-5-RIGHT...item4153126238
had some nuts all along
i had a trupart draglink end and it was shorter than the moprod one i had if that helps
Old 16th January 2011, 04:20 PM
ginger nutter ginger nutter is offline
What make of drag links are people using?
I got a Qh one today and no joy, the thread doesn't even come through the nut when in the mushroom (3ge).
Measuring the taper and thread on the ball joint there is not enough thread for the thickness of the top of the mushroom.
Wondered if another make had more of a thread on.
Old 9th March 2011, 08:49 PM
james3004's Avatar
I have this same problem, I have 3GE mushrooms and The drag links are part of a set from EDS Motorsport.
Any i deas of which draglinks fit the mushrooms properly?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 9th March 2011, 10:50 PM
gaz05 gaz05 is offline
That's the combination I,ve got and I wasn't happy with the range of movement either so I've turned 2mm off the top and counter bored the hole underneath so i could get a full nut on.
Have you tried your TREs in the Sierra upright yet. Mine didn't fit.
Gaz
Total cost so far
Materials £3,150
Tools £855
Old 10th March 2011, 05:07 PM
while i was at my very frendly autofactors getting my draglink's thay had some old stock wich i had but guy there said qh are the only people listing now and are most likely to be making all new stock for all the other supplyers now
same thing for the maxi balljoints
Old 10th March 2011, 08:46 PM
james3004's Avatar
Tried the track rod ends in and the are slightly to small, starting to look like the EDS deal wasn't so good after all
--- James ---
Flickr Album
Old 10th March 2011, 09:11 PM
yep! I emailed them and was told they were the right ones. I won't be using them again as their saver pack is going to cost me more than buying seperates.
Total cost so far
Materials £3,150
Tools £855
Old 10th March 2011, 09:13 PM
james3004's Avatar
I don't think I will be recomending them!
--- James ---
Flickr Album
