Old 13th March 2011, 04:05 PM
gaz05 gaz05 is offline
Originally Posted by adrianreeve View Post
Only other difference is the crank sensor, make sure you use the one from the manual car you had, as the auto one sits at a different angle and won't pick up the signal from the flywheel.
Adrian
I've kept almost everything from the scrap engine except Block,crank,flywheel and pistons.
I'd like a 1.8 flywheel,sump and water pump so I've decided to buy both engines, hopefully with the 1.8 ECU. That means I'll have a pre 95 1.8 for sale soon minus the bits mentioned above. (I'll fit a 2.0Lsump to it)
Total cost so far
Materials £3,150
Tools £855
