![]() Just do it you know you want too !!!!!
Pre cut chassis kit and what ever donor you can obtain,as you say its all been done so there is plenty of help. Good luck.
![]() Chassis will be a built one from saturn (would i get a discount for a nice smile lol)....its the engine i cant decide on,adore vees.Prefer a purr low revs to a scream and that applies to the women ive met over the years too lol
![]() Smile will get you no discount from Andy (
![]() 1) Make sure you built to MT75 Specification. on the tunnel as the V6 Boxes are wider than the 4pots.
2) Think about the gearbox, Type 9 V6's are costly, MT75 don't exist so have to be built from a 2.5D box and 4x4 box or with more work from a standard 2.0 Box and 4x4 box. 3) The 24V plenum will be very high, you won't get the standard saturn bonnet to fit and the enlarged one may not either. 4) are you talking Scorpio Cosworth or Granada cosworth? If the former then the BOB engine is controlled by an EEC-V ecu which has a complex imobaliser to overcome. 5) Scorpio Coswroth BOB engine will require 2 cats! 6) I tried with a 12V and have switched my plan to a 4 POT. TT
![]() Diffs are the same between Sierra/Scorp/Granada.
![]() just watch out for the 7 or 7 1/2" diff (granada scorpio) ...been there have the t shirt and a modified diff mount to fix !!
