28th March 2011, 10:00 AM
I thought the 88bhp engine was from 1996 on or at least sept 1995. I've just bought a may-95 car!! I do hope you're wrong!
From Wiki
The new 1.8 L (110 cu in) engine produced 98 kW (131 bhp), which was then increased to 99 kW (133 bhp) for the 1996 model year. The base weight increased to 990 kg (2,200 lb). Performance was improved slightly, the additional power being partly offset by the extra weight. In some markets such as Europe, the 1.6 L (98 cu in) engine continued to be available as a lower-cost option, but was detuned to 66 kW (89 bhp). This lower-powered model did not receive all the additional chassis bracing of the new 1.8 L (110 cu in). Japanese and US cars were fitted with an optional Torsen LSD, which was far more durable than the previous viscous differential.
The table above was taken from the Technical Specifications section from Wiki so looks like there is conflicting info on the same Wiki page
http://en.wikipedia.org/wiki/Mazda_MX-5
