![]() Thanks guys, great advise and confidence giving too. Thank you. I have a very good vice, I'll buy a larger hacksaw ( I only own a little one) and look out for a second hand band saw. Thanks again.
![]() Just make sure that you buy a few good quality bi-metal hacksaw blades such as Sandvick/Bahco or the likes, they will last for ages & will cut well.
It's also worthwhile investing in a small spirit level to help you clamp the piece being cut nice & level in the vice. It will greatly reduce the tendancy for a hacksaw cut to run off line. ![]() I have only got a little one but never had any complaints ![]() ![]() ![]()
![]() If you have a compressor buy an air hacksaw,makes short work of 25x25 box section and not too messy and cheap too.
![]() Have cut all mine with a Rage3 chopsaw, just make sure you clamp the material securley and it is perfectly safe, oh and dont feed it in too quickly. Its' a great piece of kit
Arfon |
![]() Quote:
![]() Thanks again peeps, I'm going to try a good hacksaw and see how I get on. I don't mind hard work as long as the cuts are accurate! |
![]() I hired a TCT mitre saw from A-Plant in Wrexham. Cost less than £50 and I cut the whole chassis in a couple of evenings. Sure I had some little pieces lefts over, but I just used a hacksaw for the one or two extra cuts.
