Hummm im not sure to be honest. I know im going to be running around 250 bhp at the wheels im using the stock wishbone design. i would think the uprights would be ok and the wishbones as well. I belive the first place to go would be the brackets would bend/twist a bit. Thats probably the first place im going to add extra strength.
Edit: Then again the wishbones were not designed for that much power heh. So maby a revisit at a later date will be worth doing. Will run with stock wishbones for a few months on the road and see how it goes.
Skyline Roadster
