Old 10th April 2011, 05:57 PM
As above,remove the lip from the drum and click them up manually,clamp off the hoses and try it and also make sure the brake light switch is not vertical as this may give you a pocket of air.
It does sound like the seal may have gone bad with the fluid moving back and forth in the tank.
