Old 11th August 2008, 07:43 PM
les g les g is offline
Default options
whoa not so fast POWLER !!!!!!
check out the diffs on the diesel estates first
the BEC crowd are paying upwards of £250 for an ultra low ratio diesel estate diff !!!!!!!!
you might be able to get the cost of your donerback and more if it has the right diff in it do a search on here and locostbuilders for the info on diff ratios and the letters/numbers on the tag you might jyst have struck gold
cheers les g
