Old 21st April 2011, 01:58 PM
Originally Posted by Eternal View Post
But on a serious note if you do make a window frame scuttle i would buy one. Also do count me in on the rear diffuser for sure.
Me too, on both counts!
Old 21st April 2011, 02:52 PM
cornishmaid cornishmaid is offline
You loose out too much having a windscreen fitted to this type of car, the wind buffeting is worse with a windscreen fitted than with simple aero screens. It's also like trying to push a door through the air as the screen tends to be quite upright and acts like a sail.
CM
Built February 2009 using Mx5 components.
Old 21st April 2011, 03:51 PM
True, but tell that to my Mrs who's worried about her hair blowing everywhere and getting hit in the face by bugs!
Old 21st April 2011, 03:53 PM
mark mark is offline
Helmet, with a pink mohican on the top.
Old 21st April 2011, 06:49 PM
Eternal Eternal is offline
still i def going the window way as want to get some wet weather gear made up. + with my engine i dont think the window will reduce the power much if anything it will probably help me....
Skyline Roadster
Old 21st April 2011, 07:30 PM
I certainly don't think power will be an issue in yours mate, you may need the extra stopping power!
Old 21st April 2011, 08:31 PM
David_17's Avatar
David_17 David_17 is offline
Looks ace andy, well done and great idea. I too will be having one. Has the price been decided yet?
*updated 7/6/11*
