Old 21st April 2011, 08:37 PM
gaz05 gaz05 is offline
Yes the backplate and carrier are seperate. What type of upright did you get because the disc and drum ones have the thick outer plate orientated differently.
This is the drum setup that I'll be using. As you can see the backplate will be sandwiched between the carrier and the upright. Then the driveshaft goes through that and the splined flange is slid onto the driveshaft and a nut spun on to hold it all together.
Total cost so far
Materials £3,150
Tools £855
