![]() Keep it simple,stripping the car loom will be a labour of love that really is not worth while in my opinion as it will be a nightmare to make tidy as I found out when trying to use the loom from the Ginetta G20 we are using for a donor.
After spending two days fitting it and trying to make it tidy I launched it out the door and went to simple wiring for starter,fuel and ignition/injection system. 7 core was used for the rear wiring and being a race car only,we only need brake and a rain/fog light and feed to the fuel pump. Premier is probably the best bet and having seen the work they produce I would use them.
