Old 22nd April 2011, 08:46 PM
Ricky Ricky is offline
Default steering column bush kit ?
I see what you mean but I still have to get that plastic thing from the uk well the whole steering column bush kit cause I can't get it here and please tell me that steel one were can I get one and does it come of any car or what ?
Old 22nd April 2011, 09:35 PM
SeriesLandy's Avatar
I'm not Too sure if you can get it in SA, it's not from a car it's just an industural bearing. Have a google the codes that are in the eBay description and you may be able to find it.
Old 22nd April 2011, 09:43 PM
Oh ok do you perhaps know the name of it or how can I find it on ebay and tell me that plastic part that I need to use would it not be ok if I made one if I ha the dimensions?
Old 22nd April 2011, 09:56 PM
The link to the bearing is in my 1st reply and the one to the plastic bit is in the one from twin turbo.
More info on the bearing
Old 22nd April 2011, 10:02 PM
Oh oops lol sorry thanks. just one more question can you mount it straight down like in that pic ir can it be in a angle or does it not really matter
Old 22nd April 2011, 10:58 PM
The two outer plates are vertical, the inner bearing moves to the angle that you need, then the two plates clamp it and stop it moving.
The bearing needs to be fixed about 15mm from the chassis so that the column is as close to the bottom of the top rail as possible.
Old 23rd April 2011, 06:06 AM
Question steering column bush kit
Thanks for the help I think that's what ill do and what do you think of me making my own plastic piece out of acetel to fit the bearing and with a round hole that grabs the column bit firm instead of the triangle hole like making it look like the bush kit one
Old 23rd April 2011, 07:50 AM
snapper snapper is offline
Totally agree with above modification, most kit cars using the Sierra column now fit this.
The original Ford bush and bearing, only being held inplace by the rubber washer, can move enough to fail IVA.
The metal bearing also allows column figment through a vertical panel.
