Old 23rd April 2011, 05:48 PM
brainbug007's Avatar
Cool cheers for the help guys, having a nightmare with this bit :| Managed to get the locknut all the down after alot of hard work with the drag link in the vice. Noticed though after putting it all together the angles looked all wrong and if you look in the picture I posted the drivers side bottom wishbones sits lower than the passenger side one. At first I thought it was something to do with the dampeners but then I realised I've not welded it in the right spot :'( So i'm going to have cut the brackets off and then make / buy new ones to get them in the right spot. I'm guessing the bottom wishbone should sit level with the ground when there's no weight in the car?
