![]() Do any of you fine guys have a good photo of the complete rear brake drum backplate with fitted springs, linings and auto adjuster arm at the top. My photo taken just before I dismantled the brakes came out too dark to make out how the hell the adjuster arm fits back on. The brakes are off an '88 2.0L Sapphire. Any help appreciated, Dave.
![]() I don't have a pic but post yours im sure its saveable, post it anyway.
Also, did you buy new springs and adjustors, mine were nackered and wondered if they are expensive? |
![]() I've got a few pics, they're just uploading. Might be of some use to you.
~ My Build Diary - http://davesroadster.blogspot.com/ *updated 7/6/11* Best bit so far: Getting it running Worst bit so far: Cutting steel for wishbones and engine mounts. Most annoying bit so far: Generator packing up half way through welding. |
![]() Any use??
![]() Serieslandy: I got a new set of springs for £6.00 from Andrew Page Motor Factors locally, the adjusters were ok. Could have done with new plastic handbrake cable inserts tho as mine seem worn.
I've tried uploading my crappy photo but it says it's above the limit of 97kbs and as I've never uploaded a pic before I'm struggling ! David17, wow what a clear photo, just what I need, I can get it done today now. It seems exactly as mine was before I stripped it down! thanks both, Dave. |
