Old 2nd May 2011, 08:32 PM
Ashtonr Ashtonr is offline
Default Towing Eye
Has anyone fitted a towing eye at the front of the chasis ? If so where's the best place and what was used ?
Old 2nd May 2011, 10:05 PM
Deanno's Avatar
Deanno Deanno is offline
HI,
I plan to put a towing eye on, well a plate with nuts welded on top side and the plate weleded to the underside of FF1 and BR7 to suit this type of towing eye:
http://www.motorsporttrader.com/en/a...wing_eye_.html
I would then use bolts with a lug on top (a bit like a wing nut but a bolt)
Hope this helps
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 3rd May 2011, 01:09 PM
I was just concerned about the strength of the chassis at the front and wether it would need reinforcing
Old 3rd May 2011, 02:24 PM
Deanno's Avatar
that would be up to you, with my mates robin hood, all he uses is a long 1tonne strop wrapped around the front lower wishbones but only to get him out of difficulty not for a long tow.
as for reinforcment i'm going to put a bit of 25x25 box from FF1 to BR7 in the centre.
but thats my preference.
hope it helps?
Dean
Old 3rd May 2011, 03:12 PM
Sounds Sensible thanks for your insight
Rob
Old 3rd May 2011, 04:05 PM
axle's Avatar
axle axle is offline
I have just put a loop (12mm solid rod) in the front facing down! Hope never have tp use it!
Regards Axle
Old 3rd May 2011, 05:59 PM
the chassis is plenty strong enough as long as you dont intend to suspend the car in the air from it. but then again i bet the chassis would still be strong enough to do that as well. 1 inch of weld will hold 1 tonne as a rough guide.
My Pictures
Old 4th May 2011, 12:01 AM
Depends who welded it!!!
