![]() I would jump at this chance I you was closer! As I'm nearly 150/200 miles opposite side haha. I personally would just get stuck in , would be a great learning curve I can find all the formulas you would need if you like or even help you calculate them myself
![]() Michael |
![]() Quote:
![]() In regards to manufacturing it myself Im an electrician by trade and have little fabrication experience and dont want to make a mess of it (am i just being a scary cat ?). Also have been looking at the prices of manifold collectors and stuff (there is not a lot available} and couldnt beleive the prices it made my eyes water ![]() In terms of the formulas for calculating the lengths etc that would be great if I do have to go down the road of making it myself. cheers Dan |
![]() http://cgi.ebay.co.uk/90-degree-Stai...item33663197d5
http://cgi.ebay.co.uk/45-degree-Exha...item3366251abc http://cgi.ebay.co.uk/90-degree-Stai...item4aa3fa6683 There are a few things that you will/may need although they are in stainless, stainless is nice! but rather expensive and im guessing if you dont want to fabricate you certainly dont want to be welding £50 worth of a bend! if you slap in on google exhaust components a few companies will pop up that will give you a rough guide . and even linco stock parts which i found out :P. i will find you the company i use there on my emails somewhere ;-) got to trail through 100 or so emails haha ! they will usually do a good deal on a bulk buy kind of thing ![]() and certainly much cheaper than other places ![]() Michael |
![]() I've just looked at the standard steel manifold on ebay, I would say have a go at doing it on the cheap and buy a second hand one. Cut 3-4 inches out of the middle of the down pipes and turn the collector round the other way then weld a 80' bend on the end of it to point down the side of the car.
I know stainless looks good but stainless manifolds crack after awhile if not done properly.
![]() Buy a race pipe for the ZX9 motor then use the manifold as it is but extend the pipe after the headers to allow the silencer to run down the drivers side...all you will need is one bend and a bit of pipe....simples and I did the very same on my daft Lotus 11 thing a few years ago....
I'm in cornwall if you fancy dragging it this far? maybe even Plymouth? |
![]() as talon says, stainless looks nice but same gas speeds can be acchived with a well designed steel manifold with heat wrap , s'all about the gas flow baby
![]() as otheres have said also i too am getting the original manifold and cutting the flange of and making it up off that . |
![]() Thanks for all the advice lads its much appreciated
![]() ![]() Again many thanks for all the advice Dan |
