![]() thanks for the reply im not quite 41mm out if i but the 40 degree angle to where it should be on SB1 & 2, the bottom of D8 sits 450mm from the base line instead of the 451.5mm i should be, meaning D6 wont fit in?
the other side of the chassis is perfect though ![]() Thanks again for all your help is much appreciated |
![]() Is the angle on the SB1 correct?It is possible that it is not leaning back the 17' over the full length of the SB1 and this would throw it out but not by 40mm+.
Are both SB1's in alignment and square? |
![]() I think the angle of SB1 is ok, because using the check dimensions on page 38, the rear face of SB2 is 151 behind the rear face BR12. if this angle wasnt right this measurement wouldnt be right? also im not 40mm out, D8 is landing 9 mm further along Br6 than what it should be if its butted to SB1/2.
