Old 21st May 2011, 06:06 PM
vetteman1355 vetteman1355 is offline
Hi
The bones sre from Saturn, and the holes measure .583" and the holes in the joints measure .380"
Nigel
Old 21st May 2011, 08:04 PM
0.583 = 14.8082mm so it looks like who ever programmed the machine misread the drawing saw 15mm which is the rad round the out side instead of cutting a 11mm hole
Moral of the storey always pull a few samples from the batch before you walk out of the door, the place I get all mine done has been caught out by RU7 & 8 before, if it's not as per the drawing I don't pay for it.
Old 22nd May 2011, 08:45 AM
MarkB MarkB is offline
Surely the jig would have highlighted the holes being a bit oversize
Old 22nd May 2011, 10:32 AM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
they only dance like irishmen in their spare time!
Old 22nd May 2011, 04:29 PM
Maybe Spud from Saturn uses some sort of step bolt, as surely this has come has come to light before if this is the way he produces them ??
Nigel
Old 22nd May 2011, 06:39 PM
Shoulder bolts are damn expensive mind you as the shoulder tends to be machined to certain sizes so they can be used as pivot bolts.
Is there enough meat in the ball joint itself to let you drill out the holes so at least they match? But then 14mm bolts is gonna be fat 'n much chunkyness
Old 22nd May 2011, 06:59 PM
Hi Mark,
It might be possible to drill the joint to 1/2" but there would be not be enough room for the bolt head or nut, I think maybe I will have to machine a counter sunk head cap screw into a shoulder bolt and re thread to maybe 3/8" or 10 mm
Another idea would be to machine up some step washers that maybe the easiest answer !!
Nigel
Old 23rd May 2011, 11:01 AM
trick-kit trick-kit is offline
Nigel
It would probably be cheaper to throw the parts away and cut new ones to the correct size than source step bolts to rectify the problem.
If the wishbone plates aren't welded in situe, the easiest option is to return them for the correct items, failing that stepped inserts would be the next best option (drilling the ball joint out would leave very little material around the bolt hole, which could lead to premature failure), as you don't want the ball joint to move under load, the main body hole already has a large clearence value on it.
TK
Innovation not Imitation!
Old 23rd May 2011, 06:08 PM
Thanks for the offer to replace the parts Andrew, but I don't think it is a big deal to make up step washers for the three sets of wishbones we have, I am hoping to pick up a lathe soon as I used to be a toolmaker before I got into real estate so it is simple job for me.
I was just not sure if there were some special bolts you guys were using over there
Nigel
