Old 22nd May 2011, 05:35 PM
carlknight1982's Avatar
Might help to put a couple of little bits of info on there mate like where your from and if you know it the diff ratio and condition etc.
Roadster No 2 build
Cost to Date : £93
Old 22nd May 2011, 06:51 PM
js1uk js1uk is offline
Look in location..
Condition of good considering it has been under car for probably 20 years.
Gearbox good what I know.
Old 22nd May 2011, 07:31 PM
MarkB MarkB is offline
Bit cheap if from an XR4i as that will be a limited slip diff and they fetch strong money.
Old 22nd May 2011, 07:35 PM
Didnt think xr4's had drums on the back ?
Old 22nd May 2011, 07:50 PM
Twin Turbo will be the one to tell.
Also I saw west midlands in your location, thats kinda a large area its like saying "South" or "London".
Roadster No 2 build
Cost to Date : £93
Old 22nd May 2011, 07:52 PM
Slippy diff is easy to indentify, turn one shaft and the other side goes same way, normal diff will have the opposite shaft turning the other way...
Old 22nd May 2011, 08:36 PM
I dont think it is a slip diff, I brought it from an Ford breakers, they said it was from an early xr4i.
Alot of ford limit slip diffs are oil packed and after 20 old years will probably need rebuilding and will work just as a normal diff.
