Old 24th May 2011, 09:06 PM
JakeH's Avatar
JakeH JakeH is offline
Hi Jake
On the engine, I think you are about OK, well very similar to my placement. I though I had a better picture on the web page but not what I thought, but this gives an indication of mine and seems same place.
I would just check the movement of the clutch arm will not foul on the side panel. As to being off slightly to one side, should not be a problem, even if you move the gear stick to the centre it would only be literally 1 mm difference to the rear face of the engine.
Adrian
Deleted my comment on the switch that looks fine.
muchos grassias adrian, perfect explanation
not had chance to work on the car for a few days but will be back to it hopefully tomorrow.
does anyone have the thickness and diameter of the landrover engine mounts? cant do much more without them. (will use some blocks of wood or something as a 'mock up'
Ta Very Much
JakeH
