Old 28th May 2011, 10:37 AM
I don't have anything else to do at the moment so I can take my time.Worst thing about the mx5 loom is that they changed them every year it seems. I've only just got hold of the mazda dealer wiring diagrams for the 94 year from a friend which are brilliant at showing everything very clearly. The mx5 looms really are a rats nest.
This link is good too!
http://www.madracki.com/miata/
I'm starting to enjoy working on the loom now it's in the garage on the build table and I can see what is what!
Old 28th May 2011, 11:29 AM
The wife's out for the day and I can't get out to the garage so I've currently got my loom spread out on the living room floor, lol
Thought I've have a go at identifying all the connectors. Wish I'd labelled them all before removing it from the car now!!!
Try this link for diagrams:
http://neomiata.com/garage/index.php...s%201990-1996/
They're not the easiest to follow, but there's individual diagrams for each year.
Old 28th May 2011, 11:41 AM
Well the first thing I'd do if I were you, speaking from experience, is check all the ecu pinout wires and colours match your wiring diagram as I went through a few before I found my M reg 95 car had a 95' year rear loom and a 94' engine, front and interior loom!
Old 28th May 2011, 12:29 PM
RAT'S NEST!
Old 28th May 2011, 06:29 PM
shh120m's Avatar
shh120m shh120m is offline
now that is exactly the reason i went with a bike engine! that would probably cause me to have a nervous breakdown
Old 2nd June 2011, 10:26 PM
YES!!! The engine still works! I only made one mistake! I put the ignition live for the Fuel Pump Relay to a dead terminal rather than the relay. Once I had then hooked up another car to the battery to jump atart it as it was flat, and tightened a bad ground hey presto my loom still works without all the other stuff, including the immobiliser. I will wait till it's test fitted to the engine in the roadster before doing anything else to it. Time to put it in a box and forget about it happy in the knowledge it worked before I put it in the box and took the engine out!
Old 3rd June 2011, 09:11 AM
Wiring loom ain't too bad, a lot of that can come out - neater than the sierra. Got ours fired up earlier in the week and it sounds sweet. Just need the prop and it's having it's first test drive of the suspension around our "private" estate. Just going to modify / shorten the prop for now.
Andrew
