Old 8th June 2011, 09:49 PM
David_17's Avatar
David_17 David_17 is offline
Thanks for all the replies.
Had another disaster, went to my lockup to give it a bit of a clean and check things over, found the brake lights have stopped working!
The pressure switch has stopped working, if i can't get hold of one first thing, im going to have to mount a micro switch under the pedal somehow.
*updated 7/6/11*
