Old 18th June 2011, 06:46 PM
misty misty is offline
Default ignition/starter switch
Hi All
On the sierra column ,on the ignition/starte switch there are 4 wires the one i am question about is the yellow wire. what is it for and where does it join onto
many thanks
Old 18th June 2011, 07:21 PM
Can't see yellow on the diagrams, unless it's different on the car side of the plug. Will pop out and have a look at the cars.
Old 18th June 2011, 07:40 PM
Scratch that, was missreading my colour codes.
yellows supply
ABS pump 1. (90spec diagram 17)
Fuse 8. Radio and heated seats. (90spec diagram 24)
Old 18th June 2011, 07:42 PM
It's basical the accessory feed that drops out during cranking.
Old 18th June 2011, 09:24 PM
yellows supply
Am I right in saying that the yellow wire is for the ABS?
