Old 26th June 2011, 06:46 AM
Davey's Avatar
Davey Davey is offline
Looking good Rob, hope the Hernia gets sorted soon.
D.
Old 17th July 2011, 09:45 PM
No news on hernia opp, but had a couple of productive evenings.
During my week off I reworked the rear uprights, got one in place mocked up
Couple of days later I went to do the other and found the shock mount was about 4mm to narrow ( dam dodgy second hand parts) tried to EASE them out but they were getting out of shape F.....K I have just wasted 3hrs reworking them and a 12MM drill bit too ( it snapped ) .. I tried to buy a single replacement but ended up with one turning up for the cost of postage, My supplier said it was a second and had been in the scrap bin but I could not tell why..
Anyway. Scroll forward.
I got a good Polo Rad ( S/H shelf wear ) and made up the mounts for that yesterday and it's sitting easonably.
I also fitted up all the wishbones and put on the shox temporarily. for mocking up. Hunted down a set of slave wheels ( they will actualy be the post SVA wheels.) Only got one on.
Whilst hunting for the wheels I found an old Sierra upper Column. These have a colapsible triangular shaft that slides up inside on nylon bushes. I had a lower column from some an old non pas sierra, and another few UJ's and shafts. Combining the sierra coulmn, the lower column, the uj gave me a space that could neatly be filled by a section of the triangular column. Perfect, Will take some pics tomorrow.
Old 18th July 2011, 08:51 AM
Sounds like you have been making some good progress Rob
Look forward to seeing some pictures
Old 5th August 2011, 07:03 PM
So all wheels have been on for a couple of weeks, and it rolls forwards and backwards ( you can even turn the prop by hand to move )
Clutch cable test fitted and works ( not a perfect fit but it works, think busing the tube would help.
Throttle cable, ( took 3 attempts to find it! ) fitted. I have had to make up a little adapter from the through pin fitting to the CVH cable end. And made up a temporrary return spring arangement that will be reworked when the box is back out.
Wired up the ignition switch and that works and starts the car nicely
Buying exhaust fittings to buld the exhaust system.
Old 28th August 2011, 09:05 PM
An exhausting few days...
I now have my exhaust all fitted up and just ready for final dressing of the welds, a job I was realy dreading ( thinking it was going to be a total PITA ) was actualy not bad.
I have a 1.8cvh with an RS turbo manifold on it.
I got a silencer a month or three back, and then guessed a selection of pipe parts ( 2x 1m , 2x 45deg 1x 33deg and a sleeve ).
I then also bought a S/H Westfield CVH 4 branch. As option 2.
last week I mounted up the silencer, and then redid it the next day as I was unhappy. I had put the bobbins to one side and the exhuats was rather bouncy with the weight to one side.. So I re-did it with the bobins directly below the pipe and it was much better.
I got the Westi manifold through the post and it was a tantalising
ly close fit. it would probably work fine if the engine was a fraction further forward...
Anyway, I bought a 3 stage pipe adapter 54mm down to 48. which was almost perfect to go onto the turbo flange of the RST manifold. A few minuets with my Engineers Fettle and it was very close indeed and welded to the flange. The sleve joint was then slid into that, the first 45 bend into that, and the second 45 bend into that. and it fitted the silencer nicely.
Welded, up and finished. Making the downpipe probably took an hour tops
She's a bit quieter now
Old 3rd September 2011, 12:25 PM
Hernia Opp is this coming Thursday, so only very light duties for a few weeks after that. 4 weeks off work to fill with doing light stuff
I need to mark up the side panel and cut out the exhaust hole so that I can remount the panel.
Think I will be making up my brake lines ( at least the flexi ones )... Got all the bits last week
Old 3rd September 2011, 03:32 PM
poshguy poshguy is offline
good luck with your op and with some light duties im sure there is planty that can be done that falls into that bracket lol
