Old 14th July 2011, 06:17 PM
you could have your dip main relay terminals mixed up so your feed is on dip and your dip wire is on the feed terminal
hope that makes sence
feed should go to dip then coil pulls on switching to high if you swith dip and feed terminals the all goes out when high is turned on
