Old 26th July 2011, 10:38 AM
brainbug007's Avatar
Hi guys, can you have a look at these 3 links and let me know if you think they've got TPS? Am I right in thinking any 1998 ZX6R model G or later has TPS? Also is this about the right sort of price to be paying at £60ish?
http://www.ebay.co.uk/itm/1998-KAWAS...em3a681 9abf8
http://www.ebay.co.uk/itm/KAWASAKI-Z...em19c74 c0f99
http://www.ebay.co.uk/itm/ZX6R-G1-98...em51914 ca914
Old 26th July 2011, 12:32 PM
I paid £30 for my zx6r tps carbs and got trumpets and rubbers with them. £70 + postage is a total rip off!
Old 26th July 2011, 12:40 PM
Did you get yours from ebay deezee? If not where from?
Old 26th July 2011, 10:52 PM
Yup, got mine from Ebay. In fact I got 2 sets as they were so cheap. Have used one for spares when servicing the other. I also got the loom of the bike for 99p + postage so I had the correct plugs.
Old 27th July 2011, 08:32 AM
That was lucky, I'm not finding anything on fleabay for under £60 that isn't badly damaged. Been trying to work out alternative models that had tps and struggling a bit there. From what I've worked out a suzuki bandit would be ok as it's also a horizontal fit but the honda cbr isn't as it's more vertical, and the yamaha ones cost a small fortune
Old 27th July 2011, 09:46 AM
You just need to sit down with ebay and manually go through the listings each week. The ones I found were listed as carburetors, not carbs. So less people were bidding on them. I only ever got them from auctions, not Buy It Now. If you go through, you can get a complete engine for the same price as some people charge for a set of carbs!
ZX6R G1 complete engine
Old 27th July 2011, 10:20 AM
Just tried calling a few local bike breakers and lowest price I was quoted was £80 for the carbs and they then wanted another £20 for tps :O I'll just have to keep an eye out on ebay.. I'm guessing it's not possible or too expense to take a non-tps set of carbs and put a tps on it?
Old 29th July 2011, 10:57 AM
Another quick question on this setup, when i put my exhaust system back on will I still need the lamda sensor as doesn't that normally connect directly into the orginal donor ecu?
Old 29th July 2011, 11:20 AM
Your lambda is redundant if your not running fuel injection. So as your going onto carbs, you can fit a blank into the hole (normally M18 fine)
Old 29th July 2011, 11:34 AM
So what does the wideband lamba option that you can get on megajolt do?
