Old 28th July 2011, 01:02 PM
misty misty is offline
Default the tunnel
Hi All
putting the electrics down the tunnel can i also use the clips the electrics are on to put the brake pipes on,
hope it not a silly question but it would make it more convenient, the petrol pipe would be on the other side away from the electrics
Old 28th July 2011, 02:35 PM
jerkins's Avatar
jerkins jerkins is offline
I would say - no.
The testers like to see everything separate - electrics, brakes, & fuel. Several reasons: loom rubbing against the brake pipe (one will wear through eventually), and brake fluid is inflammable, especially when warm - just imagine if something caused a wire to cook...
Old 28th July 2011, 02:39 PM
AH how true i will sort that now all on separate clips
many thanks
Old 28th July 2011, 09:44 PM
I run the electrics and brake lines down the right side hand of the tunnel on seperate clips, I then run the fuel line down the left hand side to keep maximum seperation. Inevitably though in the engine bay the fuel lines and electrics do cross and get very close to each other.
Old 29th July 2011, 08:27 AM
jerkins's Avatar
They can be close together, but mustn't be able to touch. What the tester will do, if he thinks there's a risk, is waggle the loom a bit to see if it can touch anything important - same for the fuel pipe. This is something you can do for yourself before the IVA!
Old 29th July 2011, 08:29 AM
great advice from you all thankyou
