Old 30th July 2011, 09:17 PM
PorkChop PorkChop is offline
Is HandyAndy still doing flat pack chassis kits? I've noticed that he hasn't posted for a couple of months (and I understand he has his reasons); I just don't want to bother him unnecessarily
Old 30th July 2011, 10:23 PM
Originally Posted by PorkChop View Post
I'm still undecided on the rear set-up but it'll either be Sierra or MX5 - it depends on how much extra space the offset MX5 diff takes up (based on Skov's build thread).
Welcome PorkChop,
You don't lose that much to be honest. Saturn have flared the tunnel out by 62mm, so you're only losing 31mm either side.
It's particularly noticable on mine as my seats are a bit on the wide side and only just fit between the rails, if they were an inch narrower it wouldn't be a problem.
Old 30th July 2011, 11:01 PM
Welcome PorkChop,
Cheers for the welcome.
That sounds good; really good It's making it increasingly likely that old 5 bits might find a new home...I'll wait until the plans are up on the SSC site and look at the dimensions before committing to a particular spec
