Old 4th August 2011, 06:32 PM
SeriesLandy's Avatar
The other thing is when it comes to mounting the harnesses. Should I go through the seats or not. Going round the transmission tunnel is fine the other side however leaves no clearance and would still run past the seat.
Old 4th August 2011, 06:53 PM
I replaced the doughnut with a group 4 escort metal u/j,if you made everything to book spec it should fit although a little close to the brace at the front. The rack should lie flat on the support frame.
Old 4th August 2011, 07:59 PM
tkpm tkpm is offline
I have the same problem with the harnesses, so i have put them around the seat for now and when i've had the IVA done, i will run them through the seats again.
Terry
Old 4th August 2011, 08:03 PM
Wynand's Avatar
Wynand Wynand is offline
I have troubles of my own with alignment of Sierra steering to the Escort 2 rack....
However, I could not fail to notice the lower wishbone nut as marked in pic below. The locknut is useless without thread going through it, and good practice learned as an apprentice is to have at least 3 threads protrude through a nut at all times.
Wynand
http://5psi.net
Old 4th August 2011, 08:13 PM
Cheers for pointing that out mate, I bought the wrong size bolts for the job and have longer ones but not fitted them yet. I think the finger tight nylock would also fail IVA.
Here is a pic of the back. I hope there is enough thread for IVA as I couldn't see anything in the manual. Are the washers essential or not as this would give an extra 4mm or so.
Old 4th August 2011, 09:30 PM
what is at the top of the tube?
Old 4th August 2011, 10:00 PM
Have a look at my build diary, there is an easy fix using a rose joint mounted of the engine mount with an additional group 4 coupling and splined shaft. Hope it helps. (This option cost a bit more money but is mechanically correct) If you need any other advise then PM me
http://www.flickr.com/photos/56936222@N04/page6/
Old 4th August 2011, 10:08 PM
The other half of the sierra steering extension, the uj that clamps on the the triangular part of the column.
