Old 8th August 2011, 06:04 PM
Tilly819 Tilly819 is offline
Oh and i almost forgot 10 points for TT and Les
tilly
www.heraldic-motorsport.co.uk
Old 9th August 2011, 02:55 PM
Ordered a new prop shaft today, might even be done tomorrow, hopefully wont be too long before its back on the road
tilly
Old 9th August 2011, 03:03 PM
once all the manifolds are back on i would try very hard to get that diagonal brace back in or at least some reinforcements as that is the weakest part of the chassis and you just made it weaker by chopping the diagonal out. managed to keep mine in with the Saab engine.
did you ever get round to playing with your suspension?
My Pictures
Old 9th August 2011, 03:19 PM
i wondered how long it would take for someone to comment on that, it is indeed my plan to replace the diagonal brace and also incorporate a second on the other side though they will not be exactly the same as they were due to the amount of space available, as for the suspension i did have a little play with it but not a lot, all theory at the moment but it certainly is possible to improve but like you said about the engine bay, the suspension can only be as good as the chassis and if the chassis flexes "which it does" then the suspension does not do what is it supposed to.
tilly
Old 9th August 2011, 10:54 PM
true but unless its a full out race car a little bit of compliance in the chassis can be helpful on poor surfaces.
My Pictures
Old 11th August 2011, 09:06 AM
Very ture, however a flexable chassis can lead to premature component failure of parts fixed to the chassis since as the chassis flexes they are exposed to stresses that they were not designed for. as you very corectly said on a race car were every gram counts and parts are shaved to a minimum then this can by crytical however on our cars this is very unlightly to be a problem due to the material thinkness and size of components spec'd in the design. it is possibe to build a far lighter stiffer chassis however i would not fancy using it on the road.
Old 11th August 2011, 11:34 AM
les g les g is offline
Hi Tilly
me and tj know a bloke who is puttin an s2000 in a robin hood
have not spoke to him for ages it might be done now...
but i have his contact details if you wanted to speak with him
shoot the breeze/or sort any snags
let me know
cheers les g
Old 12th August 2011, 07:52 PM
MarkB MarkB is offline
Why would anyone waste an engine like that in a Robin Hood.......
Old 12th August 2011, 08:03 PM
i dont care what it went in mate
he put in the engine/box and diff complete running gear
i only met him coz he sold me the diff /beam axle thing/driveshafts/uprights/drums/new brakes/new spring kits/new wheel bearings and wheel cylinders for £45
you gotta be in it to win it
cheers les g
Old 12th August 2011, 09:03 PM
I second that one it amazes me how people like to waste their money and time. A neighbor used to have a robin hood with a high power turbo cosworth in, I thought the same about that.
