Old 17th August 2011, 01:59 PM
brainbug007's Avatar
Default Steering
I'm trying to finish this part off and struggling a little so hopefully someone can help! For some reason the only place I can put my steering rack is all the way over on the nearside rather than in a central position as per the book. If it's not all the way over to the nearside, the steering extension fouls on the diagonl chassis rail Because of having to put it all the over to the nearside, I end up having to let the track rod extension out pretty much all the way from the rack on the offside to compensate. On top of that I have to almost turn the rack slightly off center with the steering wheel so to speak. I'd imagine I wouldn't be able to go full lock to lock as the rack itself isn't completely centered (I presume the trackrod would stop it turning further). So anyone have any idea where i'm likely to have gone wrong or if it will be ok like this and go thru iva?
