Old 6th September 2011, 11:36 AM
Smile Problem solved
Great I'm in for a big one
Old 6th September 2011, 12:03 PM
Sounds like a good idea Phil, there's a lot of people struggle in locating fuel tanks for the roadster and to fit them with the sender is a helpful move.
All the Best......Andrew
Old 6th September 2011, 12:15 PM
Question
How many ltrs in the long range tank Phil?
Old 6th September 2011, 12:17 PM
Can you pencil me in for a book-tub long range
Old 6th September 2011, 01:56 PM
KenK KenK is offline
Default Fuel Tank
Can I put my name down for a SSC GRP tub long range tank please.
Thanks
Ken
Old 6th September 2011, 02:26 PM
dan_g8 dan_g8 is offline
ayjay long range which type??
skov long range book tub spec
KenK long range SSC GRP
Dan_g8 long range SSC GRP
Old 6th September 2011, 05:30 PM
Ashtonr Ashtonr is offline
I recently spent a fair amount of time researching fuel tank suppliers and I was consistantly told not to use Mild steel as it rusts most of the suppliers I talked to recommended Stainless or Ally only
Old 6th September 2011, 05:48 PM
mark mark is offline
Mild steel does indeed rust but I made my own tank from mild steel 2 years ago now and its still like new
The sheet was very clean though and the exterior was powder coated
I had the sender out a couple of weeks ago and the inside is looking good
Ally tanks definately are more appropriate than steel but they can be costly in comparison, steel does the job if done correctly just like it does in lots of production cars that see more miles and winter months than our roadsters ever will!
Old 7th September 2011, 08:22 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Have a look at my powder coating system group buy saving 40quid ish on your own system at only 83 quid delivered still spaces left so get your name on the list
Old 6th September 2011, 05:47 PM
shaun shaun is offline
[quote=dan_g8;64145]ayjay long range which type??
Shaun - long range SSC GRP
http://www.shaunsroadster.wordpress.com
YOU CAN NEVER HAVE TOO MANY TOOLS!!!!
