Old 6th September 2011, 01:56 PM
KenK KenK is offline
Default Fuel Tank
Can I put my name down for a SSC GRP tub long range tank please.
Thanks
Ken
Old 6th September 2011, 02:26 PM
dan_g8 dan_g8 is offline
ayjay long range which type??
skov long range book tub spec
KenK long range SSC GRP
Dan_g8 long range SSC GRP
Old 6th September 2011, 05:30 PM
Ashtonr Ashtonr is offline
I recently spent a fair amount of time researching fuel tank suppliers and I was consistantly told not to use Mild steel as it rusts most of the suppliers I talked to recommended Stainless or Ally only
Old 6th September 2011, 05:48 PM
mark mark is offline
Mild steel does indeed rust but I made my own tank from mild steel 2 years ago now and its still like new
The sheet was very clean though and the exterior was powder coated
I had the sender out a couple of weeks ago and the inside is looking good
Ally tanks definately are more appropriate than steel but they can be costly in comparison, steel does the job if done correctly just like it does in lots of production cars that see more miles and winter months than our roadsters ever will!
Old 6th September 2011, 06:34 PM
Got to say that i build my own tank from mild steel 2 years ago to similar to the book dimemsions.
Painted in red oxided and hammerite and it looks just as good as it did the day it was fitted and was pretty cheap compared to buying an aluminum one.
Thinking about it now, the only change i would consider would be larger.
Old 7th September 2011, 08:22 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Have a look at my powder coating system group buy saving 40quid ish on your own system at only 83 quid delivered still spaces left so get your name on the list
Old 8th September 2011, 05:17 AM
Hoybi's Avatar
Hoybi Hoybi is offline
ayjay long range book tub
Shaun - long range SSC GRP
Sven - long range SSC GRP (MX-5 Sender and pumphole?????mayyyyyybe)
Hoybi - long range book tub (I suppose it can be sent to Belgium)
Eddy
www.alfaprojects.be
Old 8th September 2011, 12:07 PM
Question
x3 please phil when you can tell me how many ltrs the larger version holds.
Old 8th September 2011, 03:40 PM
Im in for that too Phil---nice one
Please see pm
Adrian
http://s1189.photobucket.com/albums/z429/ayjay50/
Old 15th September 2011, 03:09 PM
Davey's Avatar
Davey Davey is offline
Is that plastic filler pipe suitable for fuel? I only ask because it is identical to water filler necks found on many motorhomes.
D.
