Old 9th September 2011, 01:58 PM
Originally Posted by andysredmini View Post
Hi
Can anyone tell tell me if the bottom outer edge of U1 should line up with the outer edge of br7. On some pictures some have it set back like on the book drawings and others have it flush. I'm just a bit concerned that it could lead to problems when mounting the suspension brackets later on if this is put in the wrong place. looking at the mx5 guide from Saturn one of the photos shows it flush so as we are building an mx5 based car we have put ours flush for now.
I may make my suspension brackets next so i can see whats what.
The amendment to the book from Haynes states
“U1 and U2 should be fixed next, noting that they are placed square to rail BR7 at the bottom.
The top front corner is aligned with the outside of the rails TR1/TR2.”
Many thanks
Andy
If you've got the jigs and brackets, I'd definitely use them to position U1 and 2 to suit.
I placed mine so the rear top corners of U1/2 were flush with the top rails.
Luckily this had put them in the ideal position when I came to add the brackets.
The front top corners of U1/2 protruded out, but I ground grind them flush with the top rails before I fully welded them.
I think if you place them with the front top corner flush you end up having to pack the brackets out with spacers (though I could be wrong ).
