Old 13th September 2011, 12:14 PM
Originally Posted by mark View Post
Cutting your fingers off would be the easiest way!
Its almost as bad as ford sump sealant
But a quater of the cost of the ford stuff..
I remember when I was doing mine, my 6 yr old (as he was then!) was helping, all I kept saying was "Keep away from that black stuff, if you get it on your cloths your mother will kill us."
Old 13th September 2011, 11:27 PM
TT I have one of those lazy riviters as well and they make light work of all those rivets! now the floor is complete! (and i wore rubber gloves this time so no black fingers from the sealant!)
Old 25th September 2011, 08:44 PM
I have added some more pictures to my flickr account. The front end is assembled and looking nice. Notice the way I am using string instead of springs to save weight lol!
Old 28th September 2011, 08:26 PM
I have spent a little more time on my build and broke my first bit! I was tightening a bolt on a brake pad carrier and it snapped off. This mean't I had to go to AK Automotive (MX5 specialists) in Rowlands Gill for a new one. The fantastic thing is he tried to remove the broken bolt but it was well and truly stuck so he gave me a new one!! FREE. He also gave me 4 space saver wheels FREE of charge so that I can get it rolling! (on the understanding that I wont take them back to him as he has been trying to get rid of them for a while). All I need to do is get my mate to push me down the street and I will have a two seater go kart!!
Old 5th October 2011, 11:35 PM
Ive just spent the best part of the evening trying to drill out the top of my rear uprights with a 12 mm hole. If I manage to finally get through without killing my new bench drill it will be a miracle. Once this is done my chassis will be rolling!
All the bits I thought would be easy turn out to be hard work and the bits you think will be hard are easy! AGHH
Old 6th October 2011, 08:29 AM
chrisponter chrisponter is offline
Looking good David!
Old 6th October 2011, 07:39 PM
mark mark is offline
Not trying to teach you how to suck eggs, but if the drill is sharp, the speed is correct and its in a pillar drill a 12mm hole would take about a minute! even with no pilot hole
Good drills are worth their weight in gold if you are using cheapies by the way
Old 6th October 2011, 08:49 PM
thanks for the advice. I managed to get through eventually. Probably a mix of cheap drill and drill bit.
i now have my rear end assembled and two wheels on (well space savers)
I have put some more pics on my flickr acct.
Tomorrow as long as it doesn't rain I will push it out of the garge for the first time!!!
