Old 14th September 2011, 09:13 AM
brainbug007's Avatar
Default Fiberglass
I was just wondering if anyone has attempted making their own bodywork? I'd love to give a go and learn how to work with fiberglass but I'm worried about the cost side of being a false economy in that by the time I've messed a few bits up it would have worked out much cheaper to just buy it? any able to give me an idea roughly what sort of quantities of materials you need to make say the scuttle, a wing, an nosecone? the book seems to indicate that the materials are cheap if bought in bulk?
Old 14th September 2011, 09:32 AM
It is not just a case of making a panel. You need to make a buck, then take a mould from the buck, to then make the panel you require from the mould.
After playing around with modifying my dash panel with fibreglass it is a very messy / smelly job, and I would not want to have a go at making panels
Old 14th September 2011, 09:35 AM
Ya I know it would take ages, it was more if i could save myself a few hundred quid it might be worth it as a set from saturn is nearly £600 delivered
Old 14th September 2011, 10:14 AM
Most of the cost is due to the cost of materials - going up all the time, even the coloured gel coat for a body set will cost about £120. And an awful lot of man hours.
At the end of the day its whatever is best for your own build, some people have made their own bucks and bodywork to good results.
AndyH
Old 14th September 2011, 10:42 AM
So time aside though, what would the cost of materials be roughly?
Old 14th September 2011, 11:07 AM
About a third of the cost - more with VAT added, if you where making bucks then quite a lot more.
Please dont think i'm trying to put you off though it's just the question was asked....
AndyH
Old 14th September 2011, 11:25 AM
So would it just be 450g chopped strand matting, a colored polyester resin, a catalyst that I would need ignoring anything for the buck? If so how many meter's of matting and liters of resin would you recommend for say a scuttle?
Old 14th September 2011, 12:17 PM
For a scuttle:
450g csm matt: 3m
Gel Coat: 1/2 litre
Resin: 2 litres
Catalyst: 60ml
plus ancilliaries.
AndyH
Old 14th September 2011, 02:06 PM
Thanks Andy this helps Is there a good way to work out how many meters of csm you need for a wing and the nosecone? And would you say the ratio's mentioned here are about right? http://www.cfsnet.co.uk/acatalog/met...uantities.html
Old 14th September 2011, 02:28 PM
Looks about right.
