Old 20th September 2011, 06:48 PM
Tiniest amount of air will gve you a soggy pedal,air is compressable fluid is not.
If you have rear calipers make sure they are bled with the nipples upmost even if you have to remove and place them on the disc elswhere to bleed,if you have rubber flexy hoses clamp them gently and try pedal,let them off one at a time and you may find the air.
