Old 29th September 2011, 08:39 PM
mark mark is offline
If you turn it over for long enough with oil in, the light should go out (without fuel or spark at this point, but with plugs fitted)
Just ask for spark plugs for a 1.8cvh and then a plug socket to suit
Old 29th September 2011, 09:26 PM
You will probably need some choke to get it to start. Mine took a few goes to start in limp home mode to begin with.
The air noise you can hear could be the manifold leaking. If it isn't perfectly flat after you welded it up, it might not be sealed against the head correctly
Old 29th September 2011, 10:01 PM
If its not even spluttering then it sounds like your not getting any spark. I've started an engine with no exhaust, no gasket on the carbs and running limp home (10 deg BTDC) and it started fine. Ran rough as an old dog... but still started.
Old 30th September 2011, 09:27 AM
brainbug007's Avatar
Thanks for all the advice guys. I'm going to try twin's screwdriver method tonight to see if I've got a spark. The battery should be nice and full by then after charging all last nite and today to rule that out. If I've got a spark then I'll try putting some oil down the plug holes like ajay suggested and turn it over a bit to get it nice and oiled up.
I'm guessing with all of my attempts so far I should be getting close to building up enough pressure for the oil lamp to go out indicating the oil pressure has built up enough? But taking the plugs out to put some oil down will reset the pressure?
Dave when you say a bit of choke, is that different to holding the throttle open a bit? (I've got a screwdriver holding it open between a 1/8 and 1/4 as I don't have a throttle cable or choke cable fitted yet).
Old 30th September 2011, 09:38 AM
By opening the choke to introduce more fuel into the engine making it easier to start. By opening the throttle the way you have you might be leaning the mixture making it more difficult to start.
I would shut the throttle and open the choke and see what happens. You can always adjust the throttle stop screw to set the idle speed higher.
Old 30th September 2011, 10:23 AM
Any idea where the choke will be on the carbs and what it looks like?
Old 30th September 2011, 11:21 AM
In the picture you sent me of your carbs, it is the brass coloured slide at the top of the picture with a spring attached to it. You slide it to the right in the picture to turn the choke on.
http://i1142.photobucket.com/albums/...7/IMAG0048.jpg
Old 30th September 2011, 08:33 PM
You will probs need to connect this up on a choke cable once you are all sorted too, my st motor starts fine with no choke but my cvh liked the choke from cold
CBS do one that locks when you twist it
You will need some bigger jets in eventually too, my cvh was initially on standard zx6r jets and it was dangerously lean up in the rev range
Ended up with 175s or 180s cant remember which was best now on the rollers, both safe but one gave a touch more power
I might have a few sets of jets in the garage that will suit, i will pm if i find any
The standard ones were in mine at iva as it was only driven around the car park and sailed through emmisions
Old 30th September 2011, 09:40 AM
whislt the plugs are out and if your not replacing them, give them a clean with some wire wool.
Pouring oil down the bores is nothing to do with oil preasure, it's purely to try and raise compression if the rings are thought to be letting combustion past. I would imagine it would be firing anyway but a little badly.
Dirty, damp plugs is a prime suspect if there is a spark. Or Static timing.
If your drawing fuel you should smell it on the plugs.
