Old 29th September 2011, 09:19 PM
Tilly819 Tilly819 is offline
my prop has slight differences from yours in that the sliding joint is at the gearbox end and there is no torque tube
dimensions are all from the gearbox flange face:
to center UJ 665mm
to center bearing 750mm
full length at mid slide 1445mm
i also have a 10mm spacer that can be fitted on the gearbox end to make its total length 1455mm with +/- 20mm slide which is only 5mm shorter than yours which could be taken up by the sliding joint. remarkable how close they are in total length.
www.heraldic-motorsport.co.uk
Old 30th September 2011, 12:03 AM
chriseyj chriseyj is offline
That sounds like it would fit, I didnt take account of the thickness of the reverse gear either so this would take up another 3mm? Was you sprocket adapter the standard size.
How much would you want for it all? personal message me if you like or email me.
Did you notice not having the TRT tube, someone from a prop manufacturer said it isnt noticable under normal road driving, plus its expensive.
Do you still live Leicester way?
Chris
My Build Pics
Old 30th September 2011, 12:11 AM
maxubar maxubar is offline
Chris
Sorry i didn't saw your post..
CBR1000F Powered Haynes Roadster
http://www.facebook.com/#!/album.php...0&id=771932872
Old 30th September 2011, 07:31 PM
There isn't much difference between TRT and normal once under way its only really noticeable when engaging first gear at a stand still when there is a bit of a clunk, nothing serious just backlash in the gearbox and the diff.
PM on the was regarding price
cheers tilly
Old 7th October 2011, 05:55 PM
Chriseyj you have PM
Old 30th September 2011, 12:09 AM
hI. How much are you asking for the propshaft? It will fit nice on my build for the dimensions that you gave.
Thanks
