Old 1st October 2011, 07:35 PM
Big question is why?
It will add a lot of weight and reduce the steering feel and control.
Cobra that I built with a quick rack and 225 front tyres was a a chore to park. I fancied power steering but without all the crap pipe work, I was in the breakers the other day and picked up a corsa unit complete with switches and ecu, its dinky and weighs bugger all but the guy was asking £150 which I thought was ott. My nipper has a corsa and that has plenty of feel without being to vague. I will suck it and see.
Old 1st October 2011, 08:02 PM
Is it variable rate?
Old 1st October 2011, 08:27 PM
Good point . This model has but will check on the one on ebay.
Vauxhall New Corsa 3-door - Sri
SRi
The New Corsa SRi includes the following additional features over and above the SXi model:
* Progressive rate variable ratio speed-sensitive power steering
Old 1st October 2011, 08:56 PM
Found this.
The differences between these SXi cars and the less sporty models in the range extend well beyond mere cosmetic add-ons. The SXi models feature modified suspension and steering to help them live up to their sporty billing. The standard Corsa is a fine handling supermini with well-weighted and accurate steering thanks to the speed-dependent electronic power steering system (EPS). The SXi models, however, feature the more advanced VPPS (Variable Progressive Power Steering). As well as giving the steering a heavier feel at higher speeds to enhance driver confidence, this set-up also adjusts the steering ratio in response to the way the wheel is turned. As the steering angle increases, the steering gets quicker so that there’s more scope for small directional adjustments around the straight ahead and a sharper feel on the turn-in. In situations were tight, low speed manoeuvres are called for, the steering adjusts again, reducing the effort required and making lighter work of the whole process.
Old 1st October 2011, 09:04 PM
That's gong to need a speed input of some sort. otherwise it will default probably to middle assistance which would probbaly be similar to how it would be with no assistance.
Speed output probably comes from the PCM.
Old 1st October 2011, 10:03 PM
Darryl Darryl is offline
I have used a Mgf unit!
They are far cheaper then the corsa!
