  #25
Old 6th October 2011, 07:39 PM
mark mark is offline
Originally Posted by Davidbolam View Post
Ive just spent the best part of the evening trying to drill out the top of my rear uprights with a 12 mm hole. If I manage to finally get through without killing my new bench drill it will be a miracle. Once this is done my chassis will be rolling!
All the bits I thought would be easy turn out to be hard work and the bits you think will be hard are easy! AGHH
Not trying to teach you how to suck eggs, but if the drill is sharp, the speed is correct and its in a pillar drill a 12mm hole would take about a minute! even with no pilot hole
Good drills are worth their weight in gold if you are using cheapies by the way
