Old 7th October 2011, 08:59 PM
DaveyB DaveyB is offline
Default Rear drive shafts
Hi, I wonder if any one could tell me how do the rear drive shafts on the sierra mount to the diff,that being a 7 " diff . do they push in or are they bolted?. If They push in do I buy drive shafts that are splined?
Thanks
DaveyB
Old 7th October 2011, 09:31 PM
It depends which particular diff you have. I have a 3.64 lsd which has bolt on shafts. Im sure twin turbo will know more
Old 7th October 2011, 09:38 PM
This is almost 100% the case.
Rear Disk cars have bolt on lorobo shafts.
Rear Drum Cars have Push in tripode shafts.
Lorobo's can be on LSD or Open Diffs.
Push in Tripode Drums on Open Diffs.
Some Very rare cases of drums on bolt on shafts
6.5" Very Rare only push in
7" Either
7.5" Bolt on only and LSD unless a Bug Eye Scorpio which is 7.5" open.
Old 7th October 2011, 09:42 PM
Your unlikly to find any of these!
http://www.haynes.co.uk/forums/showthread.php?t=7006
Old 8th October 2011, 10:19 PM
Hi, thanks for the help, do you think it would be better to try and find an assembly of diff /drive shaft and drums that were all on the same car or would it be ok getting diff and drive shaft and then hubs all seperatley
thanks
DaveyB
Old 9th October 2011, 01:21 AM
thanks
DaveyB
Its fine as long as you mach the shafts with the diff.
saying that though its probably much easier getting it all as a set.
Old 17th October 2011, 08:32 PM
Default Lobro
Hi, could someone confirm i have this right if i come across a diff that is none lobro does that mean that the drive shafts push into it ?
I have seen some drive shafts that look like they bolt on and some that must push in, and i have seen a diff but it is none lobro i am not sure what that means. should i try and get a 3.6 ratio or 3.9.
sorry to keep going on about this
thanks for everyones help
Davey B
Old 17th October 2011, 08:36 PM
Have a scout through this site if you are new to this. all you will need to know about all the running gear.
http://www.super7thheaven.co.uk/
http://www.super7thheaven.co.uk/Sier...r_Differential
