Old 9th October 2011, 11:14 AM
MarkB MarkB is offline
I would use 2mm for the floor as it doesn't take much for something to puncture the thinner ali sheet. I don't advise welding sheet steel on the floor either as this can lead to distortion if fully welded, yet if only stitched in place it allows water and road junk to get trapped even if you use seam sealer and it will rot out just like any other car.
