Old 16th October 2011, 11:08 AM
Aussie_Haynes_MX5 Aussie_Haynes_MX5 is offline
More work done today as i have to go back to work tomorrow. Bugger. So again knuckled down and got as much of the rear sorted as i could. Unfortunately my calculations may have been a bit out as when i lifted the frame into place, it's moved if forward 15mm. Not too sure how it will go, so the MX5 is now up in the air and i've done a few rough measurements on the diff in situ. Hopefully it will be OK.
Next weekends job is to remove the diff and put it into the chassis and check dimensions and clearance. Should only take an hour or so, and then i can attempt to get the engine and gearbox out, split them and start giving them a wash. Hopefully i can lift the engine and gearbox into the frame and also see how they fit. Big plans for 2 days.
The bloke who is going to come and weld the chassis will be coming on Wednesday to have a look at how big the job is. I'm reckoning that there will be at least 2 days of work due to the heat being put into the frame.
And now for pictures . . . . . . .
